Membrane Sizing Or Calculation Literature Needed
membrane literature hollow fiber igs generon sizing calculation
#1 rasyid93
rasyid93
  • 6 posts
Posted 09 December 2014 - 09:46 AM
Hello
I am a student who is currently doing my final project. My final project is doing a preliminary design of LPG Plant. CO2 concentration in feed gas is really high (around 40% mole). To remove it, I will use CO2 membrane removal technology, which from what I learned is a best choice for high concentration of CO2. I found out that some technology can achieve a best result for this, for example IGS Generon Membrane can remove >90% of CO2, with >98% recovery of hydrocarbon gas.
I need to calculate the membrane area required, and any other spec of membrane that may be required in designing the CO2 membrane removal. I have tried looking it in some literature, but I can't find the applicable equations ( I mean, the equations i found are really complex, and I don't know if it is even commonly used).
Could you please suggest me any book or anything that could help me. Thanks in advance
Rasyid
#2 Bobby Strain
Posted 09 December 2014 - 07:11 PM
Only membrane manufacturers have what you are seeking. So I am surprised that your adviser let you pursue this subject. You might find some information within a research paper. However, when you complete this project, you will not be much wiser. Good luck.
#3 latexman
  • 1,893 posts
Posted 09 December 2014 - 08:13 PM
If the technology is a "black box", then treat it as one.  Write a performance specification.  We can help you with that, if needed.  Find a vendor who is willing to help a student i.e. no sale.  You will find one if you are polite and humble.  They were students at one time too.  They will give you a quote, physical description of the equipment, terms and conditions, maybe dimensional drawings, etc.  It's worth a try.
#4 breizh
  • 6,939 posts
Posted 10 December 2014 - 01:09 AM
http://www.membrane-...l-membranes.pdf
http://www.mtrinc.com/co2_removal.html
Let you try google and it is certainly good to follow latexman's advice.
