I'm not sure this is basic enough, but on land, the pressure at point B in a pipe which is lower than point A is always higher due to the static head. If the same pipe is immersed underwater, does the same rule still apply? Do we need to take into account the static head outside of the pipe which is no longer atmospheric?
Static Head For Pipe Underwater
Posted 18 December 2014 - 06:58 PM
Posted 18 December 2014 - 07:36 PM
What's your question?
Posted 18 December 2014 - 10:29 PM
janson,
Fliuid inside the pipe is flowing or is at static position? If is flowing, it's a gravity flow? Is the fluid is liquid or gas?
Posted 21 December 2014 - 08:43 PM
Posted 22 December 2014 - 02:15 PM
janson,
As long as the external pressure due to immersion in water don't affect the mechanical integrity of the pipe i.e. the pipe wall can isolate inside and outside of the pipe , the same rule still apply...
Posted 22 December 2014 - 03:14 PM
Static head is a potential due to the gravity toward earth center. It always exists everywhere unless you are talking about something that is not on the earth.
You should not count for the static head differences outside your piping in your fluid flow calculations because it is outside the hydraulics systems you are considering.
However, if your are calculating the piping wall stress in the deep water, you have to count for the outside liquid static changes from the water surface to the water bottom although you may ignore the static differences for the same calculations in the air because they will no more than 14.7 psi even if from the lowest valley to the highest mountain.
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
![]() Static Simulation To Dynamic Simulation Of CduStarted by Guest_tomr91_* , 09 Jan 2025 |
