Mazut Loading/unloading Pump
#1 Samin
Samin
  • 7 posts
Posted 05 January 2015 - 08:34 AM
Dears,
Which type of pumps are best suited for mazut loading and unloading in tank farms?
Mazut is highly viscose fluid.  Typically, gear pumps were used for this purpose but I have seen screw pumps also used for this as well.
Would you please consult which type of positive displacement pump is the best selection?
Maximum loading rate is 600 m3/hr (six loading arm each loading rate is 100 m3/hr for tank loading. )
Samin
Posted 05 January 2015 - 04:48 PM
Samin:
I've pumped a lot of Fuel Oil #6 - which is pretty viscous and a tough liquid to pump.  I've done this with gear pumps.  I've never pumped Russian heavy fuel oil - mazut - and I understand it is worse than #6.
I've also never pumped at the rates you are describing.  Therefore, I would not consider a gear pump as being a wise choice for such high flow rates.  A screw design seems as the more rational and logical one.  I would resort to proven mazut screw pump manufacturers and insist on a visit or two to established and operating pumping operations using these pumps - BEFORE committing to a purchase.
See the attached photos of a typical mazut screw pump installation.
Attached File  Mazut Screw Pump Installation.docx   448.4KB   27 downloads
#3 Samin
Samin
  • 7 posts
Posted 06 January 2015 - 02:03 AM
Dear Sir,
Thank you for your kind and quick response.
may be i am going to arrange (2+1) arrangement for pumps, 2 working pump and 1 stand by. so the pumping flow rate would be half of this flow means 300 m3/hr.
the viscosity of mentioned heavy fuel oil @ 100 °C is 72 cst.
i have searched in web and found screw pumps manufacturer catalogues for mazut loading arms but what was typical in our experience was gear pumps so i was not sure about the right type of pump selection.
what i have concluded from yours kind consultancy is to ask from manufactures for final screw proposal.
thanks and regards,
Samin
#4 process-man
process-man
  • 48 posts
Posted 07 January 2015 - 06:44 AM
dear Art
As you are highly experienced in heavy FO handling, we intend to desulphurize mazut 380 which contains 5 % wt. sulphur (to less than 1000 ppm). What method and supplier do you recommend?
#5 Edward_K
Edward_K
Posted 13 January 2015 - 11:41 AM
Hello, we have references on Ventbunkers in Latvia for railcar unloading system, 12 off vane pumps (with internal coating) for Russian Mazout pumping (supply Year 2003).
Edited by Edward_K, 14 January 2015 - 01:01 AM.
#6 Araboni
Araboni
  • 46 posts
Posted 31 January 2015 - 01:50 AM
Also we intend to desulfurize Mazut with viscusity of 380 cS (at 38 Deg C). Any method??
Edited by Araboni, 31 January 2015 - 01:51 AM.
