Tube Rupture Inside Hot Oil Furnace
#1 shady othman
shady othman
  • 24 posts
Posted 14 January 2015 - 01:39 AM
How can i detect - as panel operator - heavy oil leak \ tube rupture inside Hot oil furnace from Control room ( any changes in process parameters ? any alarms ..? )
Thanks in advance for your valuable replies.
#2 fallah
  • 5,022 posts
Posted 14 January 2015 - 02:11 AM
shady,
As far as I know, by installing acoustic sensors inside the combustion chamber abnormal noise due to hot oil leakage generated at or around the rupture could be detected and monitored in relevant control panel...
#3 rahulavyas
rahulavyas
  • 26 posts
Posted 14 January 2015 - 06:24 AM
The Oxygen content at the bridge wall will be a good indication of some extra combustion inside the furnce (in case of heavy leak).
one of the shell standard on furnaces also explains in detail the ways of knowing such leaks and action to be taken.
#4 senthil13
senthil13
  • 41 posts
Posted 14 January 2015 - 08:58 AM
RahulaVyas,
Can you please share the standard number with us?
Shady Othaman,
You should be able to notice level loss in the hot oil system. I'm not aware of the system that you are working. I can try to quote what i learned in a Waste heat boiler ( Tube side - process gas and shell side - steam generation) -
When we have a leak, we will be able to see quality issue in the steam. we have analyzers in the steam header to catch that. since there is a huge pressure difference between the tube side and shell side.
#5 shady othman
shady othman
  • 24 posts
Posted 15 January 2015 - 12:50 PM
thanks for all your reply
dear rahulavyas,
can you attach please shell standards on furnace
also I think may be it can be detected by installing PDI (presuure defferential indicator) for the tube inlet and outlet but I have doubt about that it may increase if there is a  fouling inside the tubes, am I correct?
Edited by shady othman, 16 January 2015 - 03:40 PM.
