Hi folks,
Just want to create a light-weight topic to hear everyone's opinion about the distinctive difference between a chemical engineer and a process engineer.
We all know both are similar. So lets discuss any possible differences.
I myself have rarely seen anyone advertising a post for 'chemical' engineer. But 'process' engineer; a lot!
One of my lecturer at university last time who taught on advanced chemical reaction used to joke saying that if we don't take advanced chemical reaction, we are incomplete as a chemical engineer, just merely a process engineer.
Have a say guys!
Process Engineer And Chemical Engineer
Started by Radionise, Apr 24 2006 01:31 PM
7 replies to this topic
Posted 24 April 2006 - 01:31 PM
Posted 25 April 2006 - 12:16 PM
Radionise,
Chemical engineering is a major you can take at a university. You get a degree such as a B.S. in chemical engineering.
After you have obtained your degree and get out into "the real world", you look for a job. There are many possibilities here, including sales, R&D, design, operations, training, etc. Amongst the many areas where you might seek employment is the specialty known as "process engineering". In simple terms, the process engineer is a member of the design team (or maybe the sole member of the team for a very small project). He works to define the process by identifying the processing steps required to achieve the desired product. He then refines the broad approach to develop and (partially) specify the equipment and instrumentation needed to accomplish this. Along the way, depending on the size and nature of the project, he may prepare Process Flow Diagrams (PFD's), Heat and Material Balances, Piping & Instrumentation Diagrams (P&ID's), and initiate datasheets which are expanded into specifications by other specialties. Process engineers could also be closely linked to operations, in which case they might be more involved in evaluating operational data and in troubleshooting. Naturally, the definition of what a process engineer is and is not is very fluid and varies from company to company.
I would say that your lecturer's idea of what a chemical engineer is leans towards the R&D side of things.
HTH,
Doug
HTH,
Doug
Posted 26 April 2006 - 11:12 PM
Pretty well defined djack.
Would just like to add that a process engineer could be seen as a plant packager, wherein he ensures that various technologies/packages/equipment are adequately provided for and properly integrated to optimally operate and control the plant (safety goes without saying).
This, as mentioned by djack, is achieved during the design process through teh development of various philosophies, design basis, pfds, p&ids, datasheets, specifications and other documents.
The above is not meant to be limiting, and defining the role of a process engineer could be continued endlessly.
Just a thought, this thread could eventually evolve into the job description of a process engineer, wherein many organisations view it as a very mechanical process (not to demean mechanical engineering) rahter than the thought provoking and innovative attitude required to achieve an optimally designed plant.
Looking forward to more inputs.
Posted 27 April 2006 - 10:01 AM
Well defined by Doug and Sandeep,
I would like to add and put it as a blend of experience and theoretical knowledge as a Process Engineer.
Chemie
Chemie
Guest_Profe_*
Posted 27 April 2006 - 03:10 PM
Let me to add a little bit of sand like a Chemical and Process Engineer:
A Process Engineer can also be called Chemical Engineer since it utilizes the basic chemical engineering fundamentals of:
1. Equilibrium
2. Thermodynamics
3. Mass and energy transfer
4. Material balance and energy balance
5. Economic balance
The process engineer utilizes Equilibrium to determine the vapor - liquid phase distribution in the various parts of a plant. He uses Thermodynamics for determining the availability of and predicting the energy and other properties of the substances he is processing, usually with a minimum amount of experimental data. He makes use of Mass and Energy Transfer extensively in his calculations of the many unit operations he performs. The Mass and Energy Balance principles are then used to develop the process specifications covering the overall plant design. The Economic Balance is utilized many times during and after completion of the design to determine the feasibility of operations, for evaluation of the design of heat exchangers and for energy recovery and the degree of distillation requirements.
One additional fundamental should be the “Judgment Balance”, since none of the other engineering disciplines make so much use of empiricism and trial and error methods. Many of our calculations are not completely rigorous, such as fractionator sizing, and judgment must be applied to the final answer.
Process engineering also makes use of most of the standard chemical engineering Unit Operations such as:
1. Fluid flow
2. Heat transfer
3. Distillation
4. Evaporation
5. Absorption and Adsorption
6. Extraction
7. Drying
8. Filtration
Process engineer deals also with most of the Chemical Processes which involve many forms of chemical reaction, including:
1. Oxidation
2. Reduction.
3. Combustion
4. Hydrogenation and Dehydrogenation
5. Isomerization, Alkylation and Dealkylation
6. Hydrolysis, etc.
Additionally: the Process Engineer must have one essential ingredient, “Common Sense” since process engineering is as much an ART as it is a SCIENCE, obtained through the years and the experience in the work's field.
Fausto.
1. Equilibrium
2. Thermodynamics
5. Economic balance
1. Fluid flow
2. Heat transfer
3. Distillation
4. Evaporation
6. Extraction
7. Drying
8. Filtration
1. Oxidation
2. Reduction.
3. Combustion
6. Hydrolysis, etc.
Fausto.
Posted 27 April 2006 - 09:37 PM
Of all the commonness mentioned, there are still some distinct differences between process engineering even say, in the same industry (i.e. oil & gas).
For instance a process engineer in the upstream business emphasises more on technical skills related to separations, multiphase flow; while a process engineer in the downstream, i.e. refinery, practices more of the chemical reaction and process integration knowledges etc.
These differences in the oil and gas business always make me think that a process engineer in the upstream seems a nearer 'cousin' to the mechanical engineer than the process engineer at dowstream who is more 'chemical'.
Posted 28 April 2006 - 08:27 AM
Radionise makes a good point. In the upstream business, processes where the most technical aspects of chemical engineering are important (such as distillation, reaction kinetics, etc.) are few and far between. As a result, quite a few upstream process engineers are mechanical engineers by training. Though I do not favor non-chemical engineering process engineers (I am a bit biased), this can work out well in industries where mechanical knowledge of the process is as important as the few technical topics where mechanical engineers would have a disadvantage vis-a-vis chemical engineers. In other words, both disciplines bring talents to the table, and there are times when the talents of one or the other discipline would be favored. That said, I think that to be called a process engineer, one should be able to comfortably attack problems involving mass transfer, reactions, kinetics, etc. One would not usually be expected to have much knowledge of strength of materials, machine design, vibrations, etc. So, I think of process engineering as being an area of chemical engineering. I invite alternative thoughts, since I think this is an interesting topic.
Doug
Doug
Posted 29 April 2006 - 07:09 AM
Interesting comments djack. My experience is actually from the upstream oil gas industry. And after my postgraduate course I will be embarking on the same industry again, but in the contracting business rather than operator.
Basically, deviations of upstream process engineers from the mainstream chemical engineering stream (if such things do exists
) is not that bad. For instance, it is common to see them working on process debottlenecking or modification process, i.e. working on scrubbers (the scrubber in upstream oil and gas is completely different from the scrubber that we learnt at university), separators, dehydration/glycol unit, sour gas treatment, removal of H2S etc, with heavy use of process simulators, which also includes dynamic simulations like modelling relieve devices etc.
One thing which is very interesting about upstream that always amaze me is in regards to any aspects that can be associated with three phase separators. designing separation equipment for upstream processes which are prone to changes of the feed conditions throughout the life time of the platform, is a big challenge. In other words, offshore processes are very very dynamic in nature. Not to mention about the slug flows in pipelines which can disturb the steady state operation of the separators. In addition, depending on the constraint of the environment, sometimes you can't just simply design a separator by following common guidelines or rule-of-thumbs.
However, in my personal opinion, those chemical engineers who are reservoir engineers or well engineers do seem to deviate a little bit further from the 'pure' chemical engineering stream. To summarise it, process engineers who works on surface operations in the upstream still utilise most skills which are within the mainstream chemical engineering. But for those who works on subsurface operations, that depends...
[Research Request] Uc Berkeley Student Seeking Process Engineers For 1Started by Guest_SangyunKim_* , 10 Jul 2025 |
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
