I am currently working on a gas processing plant offer in which the maximum CO2 content in the raw gas shall be taken at 25 mole% and 15 PPM of H2S. The chloride level in water is up to 14,500 mg/L. Operating temperature of the fluid is 250 F and operating pressure is 1186 psig. Client has asked to select appropriate / suitable CRA (corrosion Resistant Alloy) metallurgy of material. Can any one help me in the selection of MOC based on the above mentioned conditions of fluid. Please note that at downstream there is an evaporative cooler which will lead down the temperature up to 135 F. Please guide me regarding the MOC for upstream and downstream of that evaporative cooler. Can i go with SS 316 on theses fluid conditions.
