Heat Load Calculation
#1 avinashpatil2408
avinashpatil2408
Posted 21 January 2015 - 10:36 AM
Dear all,
Kindly guide me to calculate the heat load for raising the temperature of bitumen from 110 to 140 degree celcius in a tank of 15.6 m daimeter and 25 m height.
#2 Bobby Strain
Posted 21 January 2015 - 11:28 AM
We don't usually do your work for you. But if you provide the calculations then some will likely offer suggestions and advice.
#3 breizh
  • 6,756 posts
Posted 22 January 2015 - 01:48 AM
This paper will give you some information about heat transfer and thermal losses to consider for storage tanks .
You need to gather physical information about the product , the heating medium to be able to perform calculation .
Basically you need to consider to heat the fluid and also compensate the heat losses , the first part is straight forward .
#4 P.K.Rao
P.K.Rao
  • 265 posts
Posted 22 January 2015 - 01:53 AM
Multiply specific heat  (cal/gm/deg C) by mass in grams and rise in temperature in deg C and  convert to your desired units
