Dear engineers
What happen if both suction and discharge valves of a reciprocating compressor are closed but the spill back valve still open?
Posted 02 February 2015 - 12:43 AM
Dear engineers
Posted 02 February 2015 - 03:10 AM
Motaleby,
This condition should never happen for a reciprocating compressor. If you close suction and discharge valve, the hold up gas within suction valve & compressor will be discharged through spill back valve and compressor will trip on overload due to formation of vacuum in the suction.
#Samayaraj
Edited by samayaraj, 02 February 2015 - 03:15 AM.
Posted 02 February 2015 - 04:23 AM
Dear Samayaraj
Yes I know, we are working on Hazop Study of this equipment now and want to know the consequences of this faults. Some of us bielive that we will have "piping rupture or valve" , some say "compressor trip" will be occured and the rest predicted the compression will be countiued untill Ps=Pd !
What do you think now?
thanks a lot
motaleby
Edited by motaleby, 02 February 2015 - 04:32 AM.
Posted 02 February 2015 - 04:44 AM
motaleby,
Those are attending in such HAZOP meeting with having the relevant P&ID and related documents in hand have three different ideas about the consequences of mentioned valves closure. Now, how can we submit a proper response without having at least a simple sketch of the compressor system?
Please provide adequate info and sketch of the system...
Posted 02 February 2015 - 06:23 AM
A small question..Why both valves are considered as close in Hazop?
We shall not consider malfunction of both Suction & Discharge valves at same time as this is creating double jeopardy.
As asked by Mr Fallah provide additional info.
Posted 02 February 2015 - 12:29 PM
Posted 03 February 2015 - 05:14 AM
Thank you all, see the below links please:
http://img.upload724...31386575571.jpg
http://img.upload724...02692727761.jpg
http://img.upload724...03308507009.jpg
Posted 04 February 2015 - 12:16 PM
Dear motaleby,
I could not see the above said link. Attach the sketch as PDF or other format here.
I feel, Ps = Pd would never come unless the compressor is unloading.
#Samayaraj
Posted 05 February 2015 - 02:27 AM
Sorry, I've uploaded it again:
Edited by motaleby, 05 February 2015 - 11:17 PM.
Posted 05 February 2015 - 07:17 AM
The suction and discharge shut down valves are typically fail closed. The recycle and blow down are typically fail open. If the valves have pneumatic operators, the situation above happens if air pressure is lost and the blow down valve hangs up in the closed position.
It is common to start reciprocating compressors that operate at elevated suction pressure with the suction valve closed and the bypass open. The discharge can be open or closed as the discharge check valve will prevent back flow and pressurization. Usually the blowdown is cycled open and closed to allow start with minimal mass in the loop.
If the condition in the above question is reached from a running status there will be more mass in the loop. The pressure on the discharge side will drop and the suction side pressure will increase. When the loop stabilizes the discharge will be higher than the suction by the delta P across the bypass valve and pipe. If it is a multi stage compressor, the suction side pressure may exceed a component MAWP and (hopefully) a relief valve will open.
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , Today, 02:00 AM |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
![]() ![]() Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
![]() Centrifugal Compressor RecycleStarted by Guest_Lyne_* , 19 Aug 2025 |
