Relief Valve System
#1 SyedAhmed
SyedAhmed
  • 39 posts
Posted 07 February 2015 - 11:59 PM
Dear All
I have a question that during the design if I use the check valve (NRV) in relief header where different Pressure safety valve (PSV) reliefs lines are connecting so does the codes allow me to do so. I spend some time to find out in API 520 Part II & 521 but not very helpful in this regard. So if you guys have some idea or experience so please share.
Secondly what is the criteria of using spectacle blind at with the isolation valve at PSV discharge and inlet pipe?
Wait for your response!!!!
#2 fallah
  • 5,019 posts
Posted 08 February 2015 - 03:01 AM
You aren't allowed using spectacle blind along PSV inlet/discharge lines.
Also per the attached from a valid reference it's not possible using check valve in pressure relieving path such as flare header and sub headers.
#3 SyedAhmed
SyedAhmed
  • 39 posts
Posted 15 February 2015 - 07:49 AM
Thanks Fallah
Can you just tell me the attach reference that which pressure safety design practice is this so proper reference will be valid and helpful.
However as per your statement about not to use spectacle blind at the in/outlet line of PSV. The attach reference doesn't show that. Please need more clarification with reference.
#4 fallah
  • 5,019 posts
Posted 15 February 2015 - 11:26 AM
It's from following book by Nicholas P.Cheremisinoff:
"Pressure Safety Design Practices for Refinery and Chemical Operations"
Indeed, when you are not allowed using check valve at the inlet/outlet of a PSV; needles and it's not logical saying you're not allowed using spectacle blind as well...!
