Vacuum Distillation Column
vacuum distillation
#1 Donna
Donna
  • 3 posts
Posted 09 February 2015 - 08:01 AM
Hello everybody,
I am currently studying chemical engineering and have to design a vacuum distillation column. The process is actually quite simple: a solution of water with hydrogen peroxide enters the vacuum distillation column to produce a 50:50% water and hydrogen peroxide solution. The aim is to remove water from the feed, which leaves from the top .
Does anyone know the procedure for designing such a vacuum distillation column?
Thanks!
#2 Bruno Credidio
Bruno Credidio
  • 13 posts
Posted 09 February 2015 - 11:04 AM
Hi, Donna
Well, since its a binary mixture I guess you can use the McCabe-Thiele method with no problems, you just need to get VLE data for water and hydrogen peroxide for the operating column pressure.
Good luck!
#3 Jamal Nizami
Jamal Nizami
Posted 09 February 2015 - 01:00 PM
Yeah McCabe-thiele method is good for you..Is they making azeotrope?
#4 Donna
Donna
  • 3 posts
Posted 11 February 2015 - 08:59 AM
Thanks, guys. This is what I thought as well but wasn't too sure how to obtain the VLE data. In general though, will the design procedure be the same as for a normal distillation column (since this one is vacuum)?
No, it's not making an azeotrope I think.
#5 Zauberberg
Zauberberg
  • 2,728 posts
Posted 11 February 2015 - 09:04 AM
The actual VLE data should reflect the operating pressure.
