Hello!
Anybody knows how to identify that i have problems due to liquid entrainment in the compressor.
Besides the level control of the scrubber, there is another signal, such as vibrations or something else??
Thanks!!
Posted 12 February 2015 - 11:54 AM
Posted 09 March 2015 - 12:14 PM
Dear mb04,
Some indications are chambers and valves increases temperature (damage), pitting corrosion, salt deposits, and diluted lubricants.
You can review the article "Liquid entrainment" in Oil&Gas Jornal (OGJ, May 18, 2009, part 1, and Jun08, 2008 part 3).
Attached I send you another basic information.
I hope help you.
Napo.
Posted 09 March 2015 - 06:48 PM
Your query can't be addressed in a specific way without you at least furnishing the essential basic data.
For example, WHAT TYPE of compressor are you referring to? This makes all the difference in the world in addressing such a problem -- and you should know that.
If you require a logical and helpful response, you should furnish our members with ALL the basic data you have. The fluid, its characteristics, the temperatures and pressures, compressor make, size, driver, etc., etc., .......
Posted 16 March 2015 - 07:09 AM
Thank you very much Napo and Art ,
You are rigth i don“t give much information. The type of compressor is alternative and the fluid is natural gas.
The compresion ratio is of 8:1. It has a a power of 1680 BHP. The type is a valerus V-6627.
With four stages of compresion.
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
Liquid Liquid Separator SizingStarted by Guest_Kentucky08_* , 03 Apr 2025 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
