Stripping Steam
distillation column
#1 Arsal
Arsal
  • 115 posts
Posted 26 February 2015 - 11:19 PM
How to find out Stripping steam quantity in main Distillation Columns and side Strippers Of HSD and Kerosene(Calculation Required) ?
As Watkins used 8-10 % steam to bottom ratio for main distillation column?Is it accurate?
IS any other relation or thumb rule to find out the amount of Stripping steam in columns?
#2 gegio1960
gegio1960
  • 518 posts
Posted 27 February 2015 - 04:04 AM
Watkins figures can be a starting point.
As a rule-of-thumb steam to the strippers is 50% of the bottom one (so you can start with 3-5%).
Starting quantities shall be optimized since the needed quantities depend from the crude, the tower and the operation.
You can progressively lower your initial quantities and measure the effect on the product qualities:
- ASTM gap/overlap and 95% point
- freeze point of kero
- flash point of gasoil
- quantity of Heavy Gasoil in Atmospheric Residue
When the observed qualities start to be unacceptable you have found your optimal point (for that operation).
Some strippers (especially on the lighter products) don't need steam at all (but, again, it depends from the tower design and the specific operation.
#3 Arsal
Arsal
  • 115 posts
Posted 27 February 2015 - 11:20 PM
I want  some literature and calculations as well.if any please Share?
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 28 February 2015 - 05:42 AM
Look at "Handbook of Petroleum Processing" by David S.Jones, Chapter 3, Section "Side streams". Calculation procedure is available as well.
