I am emulating centrifugal compressor which is driven by variable speed gas turbine..
Compressor antisurge control algorithm , load sharing control, and performance control is built in Unit Control Panel of vendor..There is a flow element orifice installed at compressor suction which measures delta P across the orifice...Antisurge algorithm takes inputs as suction pressure, orifice delta P and discharge pressure...need your inputs as to how to implement antisurge and load sharing logic - any standard procedure from experience...
How proximity to surge is calculated and how set point is passed to antisurge controller?
Thanks,
Chetan Chavan
