Change In Ndct Diameter/height, If Splash Fill Is Changed To Film Fill
#1 ssphogat
ssphogat
Posted 11 March 2015 - 09:00 AM
CT type : NDCT
Design parameters:
Water flow rate: : 74500 m3/hr
Water inlet / outlet temp: 43 / 33 C
Air  WBT: 28 C, RH: 60%
Maximum ambient DBT:44 C.
Fill type : Splash fill
Information required:
If the fill type is changed to film fill, will the tower diameter / height, increase or decrease?
S S Phogat
  • 6,798 posts
Posted 11 March 2015 - 07:29 PM
http://www.gtpl.co.i...oling Tower.pdf
You may find answer reading this paper . Google may help you too.
Good luck.
