Hey Guys
I have set up a dynamic HYSYS model to calculate downstream pressure and temperature with respect to time during a system pressurisation.
Is there any way I can specify my downstream conditions prior to pressurisation?
HYSYS dynamics will give results assuming the initial temperature will be the worst cases isenthalpic flash temperature. In reality it wont because it will mix with the fluid already in the downstream system before pressurisation.
Thanks for any advice
