I have a Crude Column where I have a Kero draw-off and Diesel Draw-off through chimney trays. The draw-off feeds the Kero and Diesel stripper via level control valve. No pumparound is provided.
There are conflicting opinions on the residence time for the draw-off chimney trays. I have also looked up Kister's book on distillation operations and the subject has been treated somewhat ambiguously without any firm guidelines on the residence time.
Some of the opinion I have been getting for the residence time is as follows:
1. Since there is no pump-around residence time is not critical.
2. A minimum residence time of 1 minute is required irrespective of whether there is a pump-around or draw-off by level control to the stripper under pressure difference
3. A minimum residence time of 2-3 minutes is required whether it is a pump-around or a level control draw-off under pressure difference.
Assuming that the column is already in existence and the existing configuration provides a residence time of less than 1 minute do I need to modify the column by removing the trays above and increasing the chimney riser height?
Is the residence time criteria an absolute must? Will my draw-offs see flow fluctuations due to lower residence time? The operating philosophy is to run the atmospheric column at a fixed throughput (feed rate) and no turn-down or turn-up is envisaged.
Under steady state operating conditions and constant feed, are problems anticipated in draw-off due to low residence times?
Would appreciate answers from experts in design and operation of crude distillation units.
Edited by ankur2061, 18 March 2015 - 04:26 AM.
