Lpg From Natural Gas Hysys Simulation Problem
deethanizer
11 replies to this topic
#1 Steve90
Steve90
  • 71 posts
Posted 24 March 2015 - 03:52 AM
Hi everybody !!
I'am simulating an LPG extraction unit from Natural Gas in Aspen Hysys Software but the deethanizer don't want to converge .
The specification for the deethanizer are :
Component recovery propane 0.93 mole% in reboiler
component ratio methane + ethane / propane 1e-5 in reboiler
HELP please !!
A copy of simulation has been attached !
NB :I'm using HYSYS V8.6;
I created a Mega file cos i couldn't upload the hysys file :
https://mega.co.nz/#!9oUhwLJI!a2ghkjT2B22Mw_DdqH6sSoxDPnFv-db8bNuEDXVQDZ0
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 24 March 2015 - 04:17 AM
You are using the newer version of Hysys than I do. Can you upload the XML file?
#3 Steve90
Steve90
  • 71 posts
Posted 24 March 2015 - 04:27 AM
You can find here the XML fIle :
https://mega.co.nz/#!0wlDgDxY!mFo26hWBXEL9F5bBCrkA54Uki_zSmr4ZGxIUt6WveDI
#4 mr-arbdoul
mr-arbdoul
  • 3 posts
Posted 24 March 2015 - 04:40 AM
i am little confused i used aspenone v8.4 to view your simulation but some part didnt appear
#5 Steve90
Steve90
  • 71 posts
Posted 24 March 2015 - 04:43 AM
I don't know i uploaded the full simulation with the unconverged deethanizer column ! which part didn't appear ?
#6 Zauberberg
Zauberberg
  • 2,728 posts
For some reason my Hysys crashes when I try to open this XML file. You can try the following with the model:
- Remove the spec for C1+C2 ratio in the reboiler. You already have the compositional specification for reboiler (0.93% C3) so forcing the column to satisfy both compositional specs will result in non-convergence.
- Try to use another specification, which may be e.g. % C3 in column overheads. If this does not work, try playing with the % C3 in reboiler and tower temperatures in the top section. Once you get the model converged, it is much easier to play with specifications.
Let us know where you landed.
#7 Steve90
Steve90
  • 71 posts
Posted 24 March 2015 - 05:00 AM
Thanks Zauberbeg !! Before trying the proposed solutions ! i want to clarify that hysys indicates that two liquid phases were found in  the top stream leaving the deethanizer and which is blue (converged) but the entire column is yellow !!
Is this helpful for you to find a solution using my specifications ?
#8 Zauberberg
Zauberberg
  • 2,728 posts
Posted 24 March 2015 - 05:14 AM
Occurrence of two liquid phases inside the tower is not a showstopper for convergence of the model, but it has made me curious. You can double-click on the column and check liquid composition on each tray. De-C2 feed stream should be water-free. Even if in reality you have 1ppm water or less, you should completely remove water from the column feed stream. Perhaps this is the problem. If the second liquid phase is hydrocarbon, let us know what it consists of.
#9 Steve90
Steve90
  • 71 posts
Posted 24 March 2015 - 05:16 AM
you can find here the feed composition :
CO2               1,615e-003
Nitrogen         1,188e-003
H2O                9,488e-004
Methane         0,205
Ethane            0,130
i-Butane          8,76e-002
n-Butane         0,1635
i-Pentane        7,911e-002
n-Pentane       7,064e-002
TEGlycol         2,907e-005
n-Hexane        5,209e-002
Propane          0,206
and the conditions :
Vapour / Phase Fraction    0,1209
Temperature [C]                 -28
Pressure [bar_g]               15
Molar Flow [kgmole/h]    28,993
Mass Flow [kg/h]             1344,3839
#10 Zauberberg
Zauberberg
  • 2,728 posts
Posted 24 March 2015 - 05:19 AM
I think Glycol and Water are causing this issue. You can remove them from feed by using split unit operation. The problem should disappear afterwards.
#11 Steve90
Steve90
  • 71 posts
Posted 24 March 2015 - 05:36 AM
Thank you very much i removed water from the feed stream and the column converged !
#12 Zauberberg
Zauberberg
  • 2,728 posts
Posted 24 March 2015 - 05:40 AM
By the way, the De-C2 tower pressure seems unreasonably low. These systems usually operate at 30-35 barg. What is the reason for choosing 15 barg for operating pressure?
