Steam Turbine Inlet Pressure
Posted 24 March 2015 - 11:56 AM
Posted 24 March 2015 - 07:34 PM
Dear Abantikag,
You can review the GPSA, Engineering Data Book, section Prime Movers, for to find a procedure.
Maybe you need a steam at 150 kgf/cm2 (565ÂșC, with intermediate reheating).
Napo.
Posted 24 March 2015 - 11:03 PM
Posted 25 March 2015 - 07:58 AM
Dear Abantikag,
The Engineering Data Book is a Handbook, published by GPSA (Gas Processors and Suppliers Association).
Napo.
Posted 25 March 2015 - 08:16 AM
https://www5.eere.en...e?random=Outlet
Consider this resource to support your work and perform calculation.
Posted 25 March 2015 - 10:29 AM
If you have no limited condition for your steam generators (boilers), you may select steam pressure and temperature as high as you can to get more efficiency (kg steam/kw) from your generator.
Posted 26 March 2015 - 10:30 PM
Dear Napo
I have gone through 'Prime mover ' section of Engineering Handbook .But i could not find any topic which explains the procedure to select turbine inlet pressure if power output from a turbine is given.
abantikag
Posted 27 March 2015 - 12:03 AM
I agree with shan. Typically, you try your best to get the highest pressure and temperatures of steam from the steam generator, then buy a turbine that can do the job. Not the other way around...
Let me elaborate. For example, you have some hot waste gas that is of a certain flowrate and temperature. If this waste gas is 400C, then your steam temperature could never be higher than that. Therefore, the maximum amount of steam you can get is really dependent on where your heat comes from. From here, you calculate the best steam conditions you can get and select a turbine that can produce the power.
As Napo pointed out, one common pressure temperature combination is about 565C and 150Bar. Sounds like a triple pressure with reheat steam generator combination. Its a nice guideline to start with, but bear in mind, the temperatures and pressures you get is dependent on the source of heat, not on the steam turbine.
Edited by thorium90, 27 March 2015 - 12:13 AM.
Posted 21 April 2015 - 02:22 PM
Dear Abantikag,
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
