Distillation Mass Transfer Models
#1 Sadananda Konchady
Sadananda Konchady
  • 63 posts
Posted 27 August 2003 - 05:53 AM
The following 3 mass transfer options are available in my distillation simulation package.
Mass transfer coefficients for Tray columns -
1. AIChE (1958)
(Is this generally applicable to sieve trays, bubble caps trays, and valve trays?)
2. Chan and Fair (1985)
(Is this applicable only to sieve trays?)
3. Zuiderweg (1982)
While applying the AIChE model for a multicomponent distillation column I happened to get one negative value for the Murphree stage efficiency for one of the components on the bottom stage of a column. This does not seem right. Is the negative value logical? All other values of stagewise efficiency for the components were positive. rolleyes.gif
Thank you for your time.
#2 Guest_Dave_*
Guest_Dave_*
  • guestGuests
Posted 28 August 2003 - 10:12 PM
I think it's possible to get an answer for the Murphree tray efficiency that is greater than 100% (in theory), but never heard of less than 0%. Check the model and the data you are using?
#3 Sadananda Konchady
Sadananda Konchady
  • 63 posts
Posted 29 August 2003 - 06:29 AM
Thanks for your feedback. Yes, Dave, you are right about the Murphree stage efficiency. The following weblink suggests that it could be typically in the range of 60% to 120%.
http://www.euronet.n...l/TrEffGnl.html
I attempted the Murphree stage efficiency calculation using the AIChE model as well as the Chan and Fair models. In both the cases, I got negative values for the stage efficiency at the bottom of one of the distillation columns (with bubble cap trays) during the simulations. I will check with the software vendor to determine whether this is a program bug (all the other values were at least positive).
--- escape
#4 siretb
siretb
    ChE Jedi
  • 304 posts
Posted 01 September 2003 - 09:45 AM
Efficiency cannot be negative. Can exceed 100%
As a rough estimate consider the O'Connel correlation
Eff=0.492 * ( viscosity * alpha ) ^ -0.245
This has been done for bubble cap trays, conservative for sieve trays.
Alpha is the relative volatility of the light/heavy key.
#5 Sadananda Konchady
Sadananda Konchady
  • 63 posts
Posted 11 September 2003 - 11:51 PM
Hard to believe!
But the software vendor has replied that in fact the Murphree stage efficiency could be negative and has mentioned that there are some references in the technical literature about such cases, especially for multicomponent distillation.
#6 Sadananda Konchady
Sadananda Konchady
  • 63 posts
Posted 24 November 2003 - 03:45 AM
Negative Murphree stage efficiencies may indeed be possible in multicomponent distillation.
See the ternary example involving ethanol, water, and butanol in Mass Transfer by J. A. Wesselingh and R. Krishna, Ellis Horwood Series in Chemical Engineering (1990) given on pages 45 to 49
Alternatively you can click on this weblink which is a sample chapter in
http://130.161.129.68/hlf/d004ch06.pdf
Mass Transfer in Multicomponent Mixtures
prof.ir. J.A. Wesselingh and prof.dr. R. Krishna
2000 / 329 p. + CD-ROM / ISBN 90-407-2071-1 / Euro 35.85
Details of this publication are given at:
http://www.vssd.nl/hlf/d004.htm
