Material Balance For Sulfur Dioxide
materia balance extent excess air so2 so3
#1 aquaboy
aquaboy
  • 3 posts
Posted 01 April 2015 - 08:54 PM
SO2 is oxidized to SO3 in a reactor. SO2 and 80% excess air are fed to the reactor. The reaction proceeds to a 45% SO2 conversion, and the production rate of SO3 is 100 lb/min. Air can be taken to be composed of 79 mol% N2 and 21 mol% O2.
a) Write the balanced chemical reaction equation.
b) Determine the extent of the reaction.
c) Calculate the amount of air fed to the process.
  • 6,793 posts
Posted 01 April 2015 - 10:00 PM
aquaboy ,
 what is the scope ? To do your homework ?
 let us know your difficulty and we will help .
Hope you understand
Edited by breizh, 01 April 2015 - 10:04 PM.
#3 aquaboy
aquaboy
  • 3 posts
Posted 01 April 2015 - 10:42 PM
Sorry, I'm new to this forum. The only part I'm having difficulty understanding is part C. If the O2 is supplied at 80% excess, does that mean, that it is supplied at 80% excess of the stoichiometric feed?
a)  2SO2+ O2 ---> 2SO3
b) Mass balance on SO3
NSO3,OUT = 2*E
where E = extent
Solving yields,
E = 0.625 lbmol/min
c)  Find the amount of SO2 in feed then use stoichiometry to find O2 feed which then can be used to find excess air feed
fconversion, SO2 = 0.45 = NSO3,CONSUMED / NSO3,FEED = (2*E) / NSO3,FEED
Solving the above gives,
NSO3,FEED = 2.78 lbmol/min
NO2, FEED, NON-EXCESS = 2.78lbmol/min *(1/2) = 1.39 lbmol/min
NAIR, FEED, NON-EXCESS = 1.39/0.21 = 6.62 lbmol/min
NAIR, FEED, EXCESS = (1.8) * 6.62 lbmol/min = 11.91 lbmol/min
Is the bolded answer above correct?
#4 aquaboy
aquaboy
  • 3 posts
Posted 01 April 2015 - 10:44 PM
More importantly, is my method correct?
#5 breizh
  • 6,793 posts
Posted 02 April 2015 - 02:11 AM
Consider my table , results  seems to be similar to yours
