I am doing a simulation of an acetone production process. I have one requirement that the acetone is 99 wt% and has at least 12,500 kg/hr flow rate. My goal is to maximize the economic potential of the process.
When I turn off the sensitivity analysis and keep my design spec for my 2nd column to produce 99 wt% acetone, and also my other design spec for column 3 to have 100% water in the bottoms stream, I can get a convergence. However, as soon as I turn on the sensitivity analysis where I define economic potential (EP), I get a control panel error. I am not sure how to remedy this. Also, is there a way to upload aspen files onto this forum?
P.S. Why can't you paste images into your post? It would be a lot easier if you guys could see my PFD
<< All Blocks Reinitialized >>
<< Run reinitialized 10:53:16 Fri Apr 17, 2015>>
->Processing input specifications ...
INFORMATION IN THE "SENSITIVITY" PARAGRAPH WHICH BEGINS ON LINE 425
FIRST ID: EP
FORTRAN IN SENSITIVITY BLOCK WITH ID: EP WILL BE COMPILED
RATHER THAN INTERPRETED BECAUSE OF THE FOLLOWING STATEMENT:
ENERGYCOST =-.005*8000*QCOND + .03*8000*QREBOIL + 0.1*8000*WPUMP
*** SEVERE ERROR
ERROR COMPILING IN-LINE FORTRAN
COMPILER MESSAGES FOLLOW ...
ASPCOMP: Warning! Intel Fortran compiler ifort.exe not found in %PATH%
ASPCOMP: Warning! Microsoft C runtime library msvcrt.lib not found in %LIB%
ASPCOMP: Warning! Microsoft C runtime library is needed for Dynamic Linking.
ASPCOMP: Warning! Intel Fortran runtime library libifcoremd.lib not found in %
ASPCOMP: Warning! Intel Fortran runtime library is needed for Dynamic Linking.
ifort.exe /nologo /c -DAWINNTN -DWIN32 -I. "-IC:\PROGRA~2\ASPENT~1\APRSYS~1
'ifort.exe' is not recognized as an internal or external command,
operable program or batch file.
*** SEVERE ERROR
COULD NOT RESOLVE USER OR IN-LINE FORTRAN SUBROUTINE(S):
SUBROUTINE "ZZSENS" IS MISSING
*** SEVERE ERROR
PROGRAM TERMINATED DUE TO UNRESOLVED ROUTINES
! Errors while processing input specifications
Edited by Woopy, 16 April 2015 - 10:01 PM.
