Limpet Coil Theory Required
heat transfer jacket limpet coil agitator
12 replies to this topic
#1 jaggu27
jaggu27
  • 3 posts
Posted 20 April 2015 - 12:35 PM
I am a newbie to Process engineering. In my workplace we have a vessel with agitator. Now we want to cool the vessel contents by providing either jacket or limpet coil. For this we have calculated the total heat requirement and cooling water requirement. By applying the Nusselt number correlations I can find the area required in limpet coil side. Now with this area can any one please tell me the basis for choosing the coil size, and velocity of the cooling water. Also I want to know the effect of coil diameter. Kindly help me in this regard.
Thanks in advance
Jagadeesh
#2 latexman
  • 1,893 posts
Posted 20 April 2015 - 02:17 PM
An existing vessel?  Is it already in the structure or is it on the ground/in the bone yard?  Will the vessel be sent to a shop for the limpet coils or will it be attempted in place?  Have you thought about a strap-on jacket?  It might be worth considering.  It depends on the heat transfer coefficient needed.
#3 jaggu27
jaggu27
  • 3 posts
Posted 20 April 2015 - 07:20 PM
Sir its is an existing vessel and is in the structure. Our people will do the welding work in site itself. Kindly tell me how to calculate no of coils for a given area.
#4 breizh
  • 6,939 posts
Posted 20 April 2015 - 08:05 PM
http://www.cheresour...-and-full-coil/
Consider this resource available in the forum ( search engine :limpet coil).
#5 latexman
  • 1,893 posts
Posted 21 April 2015 - 07:38 AM
Calculations are great, but to maximize productivity (cool as fast as possible) the heat transfer area should be maximized where wetted inside the vessel.
Also, look at limpet coils on similar sized vessels, I think you will find the size of coils, pitch, spacing, etc. are pretty standard.
Edited by latexman, 21 April 2015 - 07:40 AM.
#6 curious_cat
curious_cat
  • 475 posts
Posted 21 April 2015 - 08:12 AM
Can you post actual numbers? What is your heat load? Vessel dia? CW temp? Process Temp.? That will constrain your choices.
e.g. Your heat load may be so high that using a circulation loop with a HEX is your only cooling option.
Or the allowable pressure drop might constrain how many turns you can use. Or what lowest half pipe dia.
#7 Napo
Napo
  • 350 posts
Posted 21 April 2015 - 08:54 PM
Dear Jaggu27,
Maybe the attached information help you.
Napo.
#8 jaggu27
jaggu27
  • 3 posts
Posted 22 April 2015 - 09:41 AM
Dear all
I want to cool, the mixture from 40 to 10 degrees celsius. Details are as follows
hot side
density : 1000 Kg/m3
viscosity: 10 CP
Heat capacity : 1.791 KJ/kg. oC
Initial temp : 40oC
Final temp: 10oC
Vessel
T.L to T.L 2400mm
2:1 ellipsoidal
1800mm ID
Agitator
115 PM
3.7 KW motor
Cooling side
Chilled water
initial temp : 5oC
heat capacity :4.1868KJ/Kg. oC
For this I got the heat transfer area as 9.3 m2 from the consultant. I need the nusselt number correlation as well as the formulas to find the number of coils required to give the above heat transfer area. Also how to choose the size of limpet coil ? Kindly help
Jagadeesh
#9 breizh
  • 6,939 posts
Posted 22 April 2015 - 11:49 PM   Best Answer
For correlation refer to the document attached.
#10 curious_cat
curious_cat
  • 475 posts
Posted 23 April 2015 - 12:34 AM
How could the "consultant" calculate the heat transfer area without knowing / assuming coil dimensions? Won't flow rate / velocity on the coil side matter?
Or was this an approximate estimate?
#11 latexman
  • 1,893 posts
Posted 23 April 2015 - 06:23 AM
I think the time to go from 40oC to 10oC is critical too.  Refer to Kern's Process Heat Transfer for the solved differential equations for many batch cooling and heating processes.
#12 breizh
  • 6,939 posts
Posted 23 April 2015 - 07:27 AM
In line with Latexman's suggestion ,consider this resource.
#13 curious_cat
curious_cat
  • 475 posts
Posted 23 April 2015 - 08:24 AM
Often, a spreadsheet where you approximate the ODE by piecewise approximations will give you a fairly close answer.
In light of the uncertainity in all the other parameters the error isn't too large.
