Steam Calculations
7 replies to this topic
#1 ProcessEng_12
ProcessEng_12
  • 45 posts
Posted 22 May 2015 - 06:24 AM
Dear all,
In the attachment given below, I have done calculation for consumption of steam on the basis of energy balance and mass balance.
My team was supposed to calculate steam taken from the 'Utility plant' as there is no measuring instrument available there. But the calculation done on mass balance contradicts the one done on energy balance.
Please review it.
Thank you in advance.
#2 ankitg009
ankitg009
  • 33 posts
Posted 22 May 2015 - 07:00 AM
Dear Nishant
You are mixing a certain amount of steam @ 18kg/cm2g and certain amount of condensate @ 25 kg/cm2g and getting steam again at 18 Kg/cm2 g. What is the basis of that. How did you came up with this?
#3 breizh
  • 6,735 posts
Posted 22 May 2015 - 07:36 AM
hi ,
http://www2.spiraxsa...ting-theory.asp
Consider this link .
Make sure your data are accurate because your steam is far from saturation !
http://www2.spiraxsa...Properties.aspx
Edited by breizh, 22 May 2015 - 07:46 PM.
#4 ProcessEng_12
ProcessEng_12
  • 45 posts
Posted 22 May 2015 - 07:43 AM
Dear Nishant
Dear Ankit,
I myself had the same doubt. We checked the measuring instruments and calibrated but they showed the same. By the away Ankit the all the pressures are absolute.
#5 Art Montemayor
Posted 22 May 2015 - 08:00 AM
Nishant:
Pay careful attention to what Breizh is telling you.  You are obviously not thinking out the correct algorithm that you have to employ to do a mass & heat balance.  This is basic chemical engineering and you must correctly think out what is happening in the process.
For example, you cannot have "condensate" (which is assumed to be saturated) at 110 oC & 25 kg/cm2A.  I believe you have your thinking all wrong and you have to THROTTLE the 25 kg/cm2 down to 18 kg/cm2 so both can mix.  Is that correct?
Another important engineering concept that you are using in a wrong way is the spreadsheet as a tool.  Never use a spreadsheet to post basic calculation data in a text box!  That is totally ignorant of what a spreadsheet tool is for.  Use the cells to contain the data and use the spread sheet to do the calculations.  Post all your thermo data in another spreadsheet within the same workbook and refer to that data in your calculations.  That way you know your calculations are correct and accurate.
Refer to the attached revision of your spread sheet.  Do the calculations the correct way and don't use a spread sheet as a bulletin board with data in text boxes.
Attached File  Book1 Rev1.xlsx   18.32KB   88 downloads
#6 ProcessEng_12
ProcessEng_12
  • 45 posts
Posted 22 May 2015 - 08:20 AM
hi ,
Sir the 41kg/cm2a steam by Utility plant is supplied to nearly 14 plants in the site. It is very necessary for them to keep the steam superheated for long distance pipelines.To get the maximum heat from saturated steam that's why more amount of condensate is required.
Thanks for the link. It will be helpful.
#7 samayaraj
samayaraj
  • 239 posts
Posted 22 May 2015 - 08:29 AM
Dear Nishanth,
Look at the sample excel sheet used to calculate amount of conditioned steam required by using desuperheater. By knowing the amount of conditioned steam at required P & T, you can calculate the amount of superheated steam and condensate required. Already I have attached a excel sheet in this forum for your query regarding temperature of depressurized steam. Kindly look at the link http://www.cheresour...reducing-valve/
Use the above excel to analyze your problem by using various function as explained in the spread sheet. Since it has steam data inbulid already which makes you work very simple.
Kindly enable macros before using this spreadsheet.
Edited by samayaraj, 22 May 2015 - 08:30 AM.
#8 ProcessEng_12
ProcessEng_12
  • 45 posts
Posted 22 May 2015 - 08:46 AM
Nishant:
attachicon.gifBook1 Rev1.xlsx
Thanks sir I will keep in mind. I will use excel workbook in the way you told.
I looked into the condensate data. It was mistake on my part that I gave the 25kg/cm2a pressure of condensate which is the discharge pressure of condensate pump. It would be throttled due to condensate control valve (desuperheating control valve) which is normally 20% open.
