Does anyone know of a credible resource that would provide guidelines for the number of air exchanges needed for a chemical storage building housing chlorine?
Chemical Building Ventilation Resource
Started by Broccoli Rob, May 27 2015 09:30 PM
Posted 27 May 2015 - 09:30 PM
Posted 28 May 2015 - 02:49 AM
Check the following pages. Some of them refer to local and/or international standards:
http://www.iecfabche...ding_design.htm
https://www.acrp.com...nloads/cs_4.pdf
http://nepis.epa.gov...ekPage=x
Posted 28 May 2015 - 07:48 AM
Thank you very much for these links. I have briefly looked through all of them and I believe they have what I need. Thanks again.
Posted 30 May 2015 - 02:39 PM
The EPA document says that complete air change should be achieved within 1-4 minutes. I suppose this is the answer you were looking for.
I Have A Question From Himmelblau's Introduction To Chemical EnginStarted by Guest_Hindxxx//_* , 27 Jan 2026 |
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
Opportunities For Heat Recovery In A Chemical Process PlantStarted by Guest_tanyongboon1_* , 29 Nov 2024 |
Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
