J_Leo:
Please be specific. There is a world of difference on how you should approach the design of an amine absorber or stripper. It all depends on WHICH AMINE you are referring to. The vapor pressure between MEA and aMDEA at the top of the absorber is very significant. You must be specific. Generalizing and dealing with the generic “amine” term will only generate general answers and responses.
I have designed a lot of “amine” units - most of them have been MEA, which I consider the worse of the lot due to the vapor pressure, degeneration rate, and corrosion problems. I even locally fabricated and installed some units in developing countries. They all worked - and for a long time. I started working with MEA when the first edition of Arthur Kohl and Fred Riesenfeld’s book, “Gas Purification” was published and didn’t buy a copy of it until 3 years later, when I had already experienced in the field most of what they wrote. The book was later re-born with Kohl and Neilsen as authors - but with still the same, basic information and not too much new or radical discoveries. Attached find a section of the 5th edition. Note how the authors avoid any attempt to cite specific design methods, sizing, or detail calculations. They don’t know how to determine the correct size of the towers, the proper internals for a specific case or the best, proven solution concentration for a specific application. An example of the current state of stripper design for MEA plants today (as it was over 50 years ago) is that a so-called “reflux” is employed on the stripper tower. No one in the industry, the countless papers, drawings, operating manuals, and text books on amine units for acid and sour gas removal have ever (to my knowledge) ever explained in detailed, engineering logic as to why a weak MEA aqueous solution is returned back to the stripper to add more size and reboiler duty requirements to the system. Everyone just says that you have to use a reflux system on the MEA stripper. It makes no scientific or engineering sense to think that you can “reflux” a top product that is a gas. Every student in a distillation course knows that reflux is used to establish an equilibrium on the top tray and set the overheads product purity. This is not what a stripper is supposed to do. It is supposed to just simply strip out a non-condensable gas out of solution. And, in an MEA stripper, I have done this with no more than six trays - not the 14 to 26 trays as recommended.
So, I’ve answered your specific question. I can also add that I used the book to calculate the required MEA solution rate. However, as you can see if you carefully study the book, the design and fabrication of the absorbers and strippers as done by almost all engineering contractor firms is done on an empirical and field proven basis. This is obvious in most cases to avoid liability issues on performance. Some of the designs I’ve seen in the field have been ludicrous and exaggerated in design and dimensions. This is unfortunate because, as I suspect, most - if not all - of the design engineers involved have never built, installed, or fabricated an amine unit. They have followed past, proven designs and relied on meeting contractual terms.
You can simulate all your heart desires. But the bottom line will always be: what is your experience in operating the specific operation and what will you guarantee as the essential equipment to carry out the specified operation and yield the desired product?
As you suspect, you had better have second thoughts about how much faith you can put on a stupid computer’s output. In the end, it’s not the computer who will have to respond to claims of “lack of performance”. It will have to be you. If you have not done this before with repeated success, then heed what our esteemed forum members have so expertly replied: leave it to someone who not only has justifiable claim to being an expert, but will also back up the results with legal responsibility.
I hope this experience helps out.
Acid Gas Removal Design Criteria.docx 111.38KB
309 downloads
