For some reason I can not figure out this issue. The issue is that the Rich Glycol in the Low Temp. Separator level builds and can not escape through the Level Control Valve or the Bypass line around this valve.
The LCV is not plugged, is sized correctly, and is totally functional.
The Bypass line around the LCV i mentioned above is not plugged neither.
The piping that goes from the Low Temp. Sep. to the still stack on the Reconcentratoris not plugged neither.
The glycol filters are not plugged.
There is no plugging issues anywhere. (Trust me, I took apart everything including valves, piping and still stack)
The flash separator pressure is around 60 psi.
We are injecting 80% Glycol at .6 gpm to 3 injection points at 500 lbs. each
The incoming gas to the G/G exchanger is around 85 degrees Fahrenheit and 400 psi
The LTS is -35 with usually 360 psi on it
I will explain the flow
Rich Glycol leaves the Low Temp. Separator at -35 degrees Fahrenheit and at 380 psi through a Level Control Valve.
Rich Glycol is directed to the Reconcentrator Still stack to get warmed up
From the still stack it is directed to the Reconcentrator Surge tank to be warmed up again.
From the surge tank it is directed to the Flash Separator
From the Flash Separator it is directed through a Particulate Filter then through a Coal Filter
From the Coal filters it is directed to the Still Stack, where it finally comes into contact with the vapor from the reconcentrator and goes through pall rings and rains down into the reconcentrator
From the reconcentrator it is now Lean Glycol and Flows into the surge tank where, our Glycol Injection pumps it back to a Gas to Gas exchanger, Gas to Cond. exchanger, and to our Gas Chiller.
For some reason could there be issues in the still stack when the still stacks temperature fluctuates from 200 degrees to 60 degrees? Meaning the glycol hydrocarbon carryover from the LTS is dropping out more when temperatures are too hot and the hydrocarbon starts to freeze up when the temperatures in the still stack start to decrease causing pluggage?
Are we running too cold or too hot in certain areas?
Is my Glycol concentration too high at 80% glycol?
I have no clue whats going on and if you need more information on anything let me know!!!!
Edited by fuzzhezy, 18 June 2015 - 12:11 AM.
