Heat Loss In Injection Of Direct Steam In Vessel
#1 shamir
shamir
  • 25 posts
Posted 24 June 2015 - 01:56 AM
    How to calculate  heat loss if steam of 3 kg/cm2  is directly injected in open tank containing water.
  • 6,722 posts
Posted 24 June 2015 - 02:02 AM
Unclear ,
All the energy coming from the steam  ( sensible and latent ) heat is taken by the water .
#3 samayaraj
samayaraj
  • 239 posts
Posted 24 June 2015 - 08:48 AM
If you are talking about saturated steam, the enthalpy is nearly 2724 kJ/kg for 3 kg/cm2 pressure (You can get the data from steam tables). Heat lost by the steam you can calculate by subtracting the enthalpy of steam and enthalpy of water at given temperature.
Edited by samayaraj, 24 June 2015 - 08:58 AM.
#4 Art Montemayor
Posted 24 June 2015 - 08:53 AM
Breizh is absolutely correct.
Are you trying to heat up the water by using direct injection of live steam?  If so, there is no heat loss involved; there is a direct heat transfer from the steam to the water - via its latent and sensible heat properties, as Breizh states.
#5 Bobby Strain
Posted 24 June 2015 - 11:10 PM
Your query is very ambiguous. Want to clarify?
