Pressure Drop Calculations Required For "coefficient Of Discharge
#1 ryn376
ryn376
  • 94 posts
Posted 24 June 2015 - 12:35 PM
Is it required to calculate inlet and outlet pressure drops when sizing a rupture disc using the "Coefficient of Discharge Method"? To me this seems unnecessary as pressure drop is required for PSVs since larger pressure drops have adverse effect on the relieving of the PSV. The pressure drop should be limited by the short distances required to follow the "8 and 5" rule. Thanks.
#2 Bobby Strain
Posted 24 June 2015 - 02:32 PM
I don't understand what you are referring to. I always sized the rupture disk and piping associated with a rupture disk using the K, or resistance, value for the rupture disk.
#3 breizh
  • 6,732 posts
Posted 24 June 2015 - 07:21 PM
ryn376 ,
Consider reading the document attached to clear your doubts.
http://www.cheresour...ngineers-part-2
Edited by breizh, 02 July 2015 - 12:31 AM.
#4 latexman
  • 1,816 posts
Posted 24 June 2015 - 08:56 PM
When a rupture disk bursts, there's no inlet or outlet, just total length of pipe with a ruptured disk (kr) in it.
#5 ryn376
ryn376
  • 94 posts
Posted 30 June 2015 - 01:29 PM
The disc type requested by my client does not have a Kr value, therefore I cannot size it per the standard resistance coefficient method.
#6 breizh
  • 6,732 posts
Posted 30 June 2015 - 09:31 PM
ryn376 ,
Why don't you ask the vendor ? Should not be a problem .
my 2 cents
Edited by breizh, 30 June 2015 - 10:28 PM.
#7 latexman
  • 1,816 posts
Posted 01 July 2015 - 06:11 AM
How does the vendor characterize the frictional losses of your rupture disk?   If it's not in the documentation for your rupture disk, do as Breizh recommends, ask the vendor.
