Hi! I am looking for some way to treat an effluent stream which contains heavy aromatics in gas phase. This is for a final project in a subjet. I would really appreciate if someone can suggest something.
Heavy Aromatics Gas Removal From Effluent Stream
Started by Gldzm, Jul 02 2015 04:34 AM
Posted 02 July 2015 - 04:34 AM
Posted 02 July 2015 - 04:38 AM
This option might be suitable for you.
https://en.wikipedia...as_purification
If you share the inlet and outlet gas composition, it might help you even more.
How To Remove The Condensate In A Wet Gas StreamStarted by Guest_ksagarzazu_* , 25 Feb 2025 |
![]() Moisture Removal From Blower AirStarted by Guest_Makarove_* , 12 Jul 2024 |
Condenser Inlet Stream TemperatureStarted by Guest_Sampath123_* , 06 Jul 2024 |
Hysys Stream WorksheetStarted by Guest_nasim304_* , 22 May 2024 |
