Generally, I wouldn't mix two streams operating at a different pressures but sometimes, it is done for certain reasons. The condensate stabilizer is a distillation column operating along the pressure profile of 1136 kPag to 1106 kPag. Can a stream operating at 1002 kPag be routed to such a stabilizer? If not so, why?
Posted 07 July 2015 - 03:04 AM
Posted 07 July 2015 - 06:07 AM
No. It is impossible for lower pressure stream to flow into higher pressure column.
Posted 07 July 2015 - 10:33 AM
Mathi,
Shan is absolutely correct, but you can install a pump.
Napo.
Posted 07 July 2015 - 10:58 AM
Mathi,
In fact, you should ask: Is so, why?!
Posted 07 July 2015 - 04:54 PM
Mathi,
Please note that it is always the flowrate you need to deliver and not the pressure.
If you route a stream as the feed to your column, then its operating pressure is no longer 1002 kPa(g), but is the column pressure plus the inlet device (if any) and the nozzle pressure drop, as It will be hydraulically balanced. But you cannot do that in a simulation software. However, as stated above you will not get the same flowrate passing through the upstream valve or pump or whatever equipment once considering 1002 kPa(g) as the operating pressure. Also, the stream phase may change depending on the equilibrium curve.
Best,
Milad
Posted 08 July 2015 - 12:02 PM
Mathi,
The answer to your question is yes. But your question is very vague, hence the responses you get are maybe not the answer to your question. In future posts, be more specific, and provide more information.
Posted 08 July 2015 - 01:22 PM
Mathi,
Bobby,
Then, at least say: the answer to your question MIGHT BE yes...
How To Remove The Condensate In A Wet Gas StreamStarted by Guest_ksagarzazu_* , 25 Feb 2025 |
Off Spec Condensate Storage TankStarted by Guest_shekhar dhuri_* , 05 Sep 2013 |
![]() ![]() Steam Condensate Pipeline Water HammerStarted by Guest_kaidlut_* , 06 Sep 2024 |
Water Content Of CondensateStarted by Guest__1angelia23_* , 10 Jul 2024 |
![]() Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
