Design Pressure Of The Pipe
#1 krishnamurthy
krishnamurthy
  • 58 posts
Posted 07 July 2015 - 11:12 PM
how to fix the desing pressure of the pipe? Is there any exact formula to calculate the design pressure of the pipes. kindly explain.
#2 samayaraj
samayaraj
  • 239 posts
Posted 08 July 2015 - 02:20 AM
Design pressure of pipe is generally taken as centrifugal pump shutoff head or the safety valve set pressure.
#3 Zauberberg
Zauberberg
  • 2,728 posts
Posted 08 July 2015 - 03:32 AM
Are you asking about selection or calculation of the design pressure/MAWP? If you are interested in calculation, look at the piping code your project adheres to - usually based on ASME B31.3 if process piping is in question.
#4 fallah
  • 5,019 posts
Posted 08 July 2015 - 04:29 AM
krishnamurthy,
As zauberberg mentioned you should refer to relevant piping code; for example in ASME B31.3 the design pressure, in brief, is a pressure value which with coincident temperature will lead to highest pipe thickness...
#5 farid.k
farid.k
  • 384 posts
Posted 11 July 2015 - 07:57 PM
from my experience,
generally, process design pressure is maximum possible operating pressure + 1 barg OR maximum possible operating pressure x 110%.
Edited by farid.k, 11 July 2015 - 07:59 PM.
