Pump Head And Pump Curves
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 02 August 2015 - 11:29 AM
I am reviewing some pump curves which are all based on water, i.e. Sp. Gr = 1.
The pump is specified for 1.6 sp. gr. fluid. The pump head is 20 m according to the vendor curves which gives us an output pressure of
Sp. Gr x g x h = 1 x 0.0981 x 20 = 1.962 bar.
The required pressure output is 4 bar, so for water the required head is 40.77m. With simple math, if I were to calculate the pump head using the 1.6 Sp. Gr, can I say that the required head is 40.77 / 1.6 = 25.48?
So the equation would read 1.6 x 0.0981 x 25.48 = 4 bar?
Your feedback is appreciated
Sherif
#2 thorium90
thorium90
  • 1,073 posts
Posted 02 August 2015 - 05:50 PM
I don't quite understand. The pump curve is based on SG=1 and the pump is "specified" based on SG=1.6? That doesn't make sense.
Also note that if the SG is different, you might require a different motor size or you might end up overloading your motor... If the pump is designed for a particular fluid, it might not be suitable for another fluid.
Edited by thorium90, 02 August 2015 - 05:54 PM.
#3 breizh
  • 6,732 posts
Posted 02 August 2015 - 07:17 PM
This document may clear your doubt.
Good luck,
#4 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 03 August 2015 - 06:16 AM
thorium90,
I meant the pump curves are flow vs. head and head is usually estimated in meters/feet of water.
Sherif
#5 PingPong
PingPong
  • 1,466 posts
Posted 03 August 2015 - 07:20 AM
No. Head is specified as meters LIQUID, irrespective what the s.g. of that liquid is (but assuming its viscosity is not much more than that of water).
So a centrifugal pump with a Head of 20 m will give a Differential Pressure of 2.0 bar with water (s.g. = 1),
or only about 1 bar with LPG (sg = ~0.5), or 3.2 bar with a liquid that has a s.g. of 1.6
