i need rotary and reciprocating pump equations to calculate discharge temperature
can you please suggest what kind of methods available to calculate discharge stream properties of the pump
Posted 13 August 2015 - 03:49 AM
Posted 13 August 2015 - 06:08 AM
Consider this resource , you may find answers to your query . You should also consider the search engine in this forum to support your work.
Edited by breizh, 13 August 2015 - 07:02 AM.
Posted 13 August 2015 - 09:31 AM
Why do you claim that a positive displacement pump will discharge its liquid at a temperature different than its suction temperature?
Pumps pump liquids; compressors compress gas. Positive displacement compressors adiabatically compress the gas handled and raise its temperature according to the adiabatic process involved. Discharge temperature due to pumping liquids in a pump is something strange to me. Are you confusing liquid pumping with gas compression? And even if there is a temperature increase, it is so slight that it never has come into question in my experience.
I am assuming we are dealing with a steady state pumping operation. If the pump's discharge is closed, or excessively throttled, that is another question - and you haven't defined it.
Posted 14 August 2015 - 04:32 AM
Thank you
Pulsation Device In Reciprocating CompressorStarted by Guest_zaidanamir_* , 17 Feb 2025 |
