I'm designing an adsorbent system for removing Carbon Dioxide from a Carbon Monoxide gas stream. I need to ensure that the adsorbent system will not add any impurities to the gas stream.I tried looking up literature but could not find a design guideline for an NaOH based unit. The system specifications are as follows:
CO Gas Flow Rate: 200SLPM
CO Gas Pressure: 1-36 Bar (Variable)
Temperature of Gas Stream: 300Kelvin
CO2 Concentration (Inlet Stream): 200PPM
CO2 Concentration (Outlet Stream): <1PPM (After passing through adsorbent system)
Breakthrough Concentration (CO2) : 1PPM
Designed Changout time: 30 Days
Adsorbent System is operated 24x7
-------------------------------------------------------DESIGN-------------------------------------------------------
Contaminant Information:
Max CO2 concentration is 200PPM,
Therefore, 1L of gas has 1L*200*10^-6 = 0.2ml of CO2.
From Ideal Gas Law, 22.4L ---> 44g of CO2 ====> 1ml of CO2 --> 0.4*10^-3g
Total CO2 contaminant generated by flowing 200SLPM of gas in 1 day
= 200 * (0.4*10^-3) * (60 *24) g/day
= 115 g/day
Total Contaminant to be removed in a Month = 115g/day * 30day = 3,450g = 3.45Kg
Adsorbent Information:
The Adsorbent being used are pure dry NaOH Pellets.
https://www.merckmil...MDA_CHEM-106462
Assume NaOH pellets can adsorb 10% or (0.1) by weight of Carbon Dioxide. (I'm making a wild assumption without any basis. I need help on this.)
Kg of NaOH needed per month = (Amount of Contaminant to be removed) / (Amount of CO2 adsorbed by NaOH)
= 3.45Kg/ 0.1
= 34.5Kg
Safety Factor of 1.75
==> ~60Kg of NaOH/month is needed.
Vessel Sizing:
Adsorbent used in industries have a superficial velocity between 5 to 50cm/s (Using lower value. I'm not sure what is perfect for NaOH pellets)
Q = Gas Flow Rate = 200SLPM
Qa= Actual Gas Flow rate = Q/ sqrt(System Pressure) //Pressure of the system varies between 1-36Bar
Qa = 200LPM to 33LPM.
Use the higher flow.
Superficial Velocity = Actual Flow/Cross-section Area
==> Diameter = Sqrt(4*Qa/ pi*velocity) = 29cm
For simplicity, Choose Vessel Diameter = 30cm
Density = Mass/Volume [Density of Sodium Hydroxde Pellets = 1g/ml ; Density of NaOH = 2.13g/ml]
==> Vessel Height = 4*M/(pi*D^2 * density)
Vessel Height = 85cm
Contact time with adsorbent = Volume of Vessel/Superficial Flow = 18s (Is this sufficient?)
This unit is followed by a Mol-Sieve 13x unit which has a diameter of 8cm and height of 100cm. This is to remove any trace water that is picked up by the gas streams.
-------------------------------EXPERIMENTS TILL NOW-------------------------------------------
I tried building smaller prototypes to test if this system would work. The first time around, I built a unit with a Diameter of 2.5cm and Height of 100cm. It was loaded with ~0.75Kg of NaOH. This was expected to work for an hour or so. But the system did not work. CO2 levels in the system would saturate at ~1000PPM and stay there. i.e It was incapable of bringing CO2 to below 1PPM but was good enough to adsorb excess CO2 being generated by the system. This system used a gas pressure of 20Bar.
I built a larger unit, with a diameter of 9cm and a height of 100cm. It held about 5Kg of NaOH pellets. But this could only bring down CO2 levels to ~250PPM. It would adsorb the additional CO2 that was being added but could not bring the levels to required. The system pressure for this was again 20Bar.
My doubts for the new system are:
I think the very low CO2 removal I'm getting is because of using dry pellets as is. Am I using NaOH pellets in an industrially acceptable way? I've read often that wetted NaOH pellets are excellent CO2 adsorbents. But how do I wet them? Do I pour a few drops of water. When I tried pouring water, I always found that the wetted NaOH pellets would melt, reform and impede gas flow substantially. Is there a thumb rule I can use?
Are my assumptions for contact time proper? Is there an "acceptable" contact time for NaOH pellets to remove CO2?
Is the vessel sizing I've used something that will work for a month?
Looking forward to tap into the forum's experience to design this system.
