Evaporative Coolers: Plant Practice
#1 curious_cat
curious_cat
  • 475 posts
Posted 19 September 2015 - 08:23 AM
I came across an interesting equipment described in Minton's excellent book on Evaporators: An evaporative condensor. It seems like a cross between a Shell and Tube and an air cooled HEX.
Is this equipment used in practice? Isn't it sort of like trying to combine a mini cooling tower with your shell and tube? What's the advantage to doing this rather than a conventional CW circuit and a stand alone, centralized, large Cooling Tower.
#2 PingPong
PingPong
  • 1,474 posts
Posted 19 September 2015 - 10:28 AM
Yes. Baltimore Aircoil Company is a well known supplier.
http://www.baltimore...tive-condensers
Yes, it is.
Process fluid in the tubes is colder (closer to wet bulb temperature) than when using CW from a conventional system.
Probably cheaper if there is only one large CW user. It is however possible to have additional CW from the bottom to supply some other small CW users.
Edited by PingPong, 20 September 2015 - 06:30 AM.
#3 Bobby Strain
Posted 19 September 2015 - 12:03 PM
These carry the moniker  WSAC, for wet surface air cooler. Typically the tube and fin material is a stainless steel alloy to handle the corrosive water environment. If you search using the moniker you will find lots of information.
Edited by Bobby Strain, 20 September 2015 - 09:00 AM.
#4 breizh
  • 6,940 posts
Posted 20 September 2015 - 06:15 AM
A review  of technologies .
Hope it helps you .
