Vacuum Unit Transfer Line Calculation
spreadsheet & simulation
#1 Daniel001
Daniel001
Posted 01 October 2015 - 11:18 AM
I've to check and existing Vacuum Unit transfer line and I wanted to know if there is any paper or spreadsheet/simulation example to learn on how to do this check. I wanto to know if we have chokec flow at any point in the transfer line. Could anybody help? Thanks!!
  • 6,755 posts
Posted 01 October 2015 - 07:21 PM
Daniel001,
To start with , you may read the documents attached .
Hope this helps you .
#3 gegio1960
gegio1960
  • 518 posts
Posted 04 October 2015 - 03:23 AM
Daniel,
I've specific knowledge of these systems but I don't know how to help you.
For istance, I never needed to analyse the possibility of choked flow...
Unfortunately Breizh docs are not very helpful for your case, ie 2-phase flow at very low pressure with varying L/V ratio.
Could you kindly tell me what is the main diameter of your VTL?
Good luck!
Edited by gegio1960, 04 October 2015 - 03:23 AM.
#4 PingPong
PingPong
  • 1,468 posts
Posted 04 October 2015 - 05:03 AM
Read article "Stepwise Simulation of Vacuum Transfer Line Hydraulics" in PTQ 2009 Revamps:
http://www.digitalre.../2032560244.pdf
