I'm running a Sep block in my model and just specifying split fractions for one of two outlet streams. Basically I'm saying send 90% of the water to stream 1 and everything else to stream 2. I keep getting this error
Posted 22 October 2015 - 03:58 PM
Posted 22 October 2015 - 10:20 PM
Is this block in some recycle loop? Maybe a screen snapshot would get you some answers.
Posted 23 October 2015 - 02:30 PM
I've added it to a recycle loop, but this was happening before that. This is my process, and the mass imbalance is only getting worse....
everything in the snapshot with an error is out of mass balance
Posted 27 October 2015 - 09:41 AM
1. Is stream "CO2OUT" specified as a tear stream @ Data Browser>>Convergence>>Tear>>Specifications ?
In my opinion, the best thing to do is to tear only stream "S1". In this way an estimation of components flow rates and P, T for this stream would be enough for solver of tears to calculate the rest of ops and stream. In other words this decision involves the minimum number of tears to break all loops.
2. Make sure that there are coherent design specs, e.g. make up streams components flow rates are varied in order to suppliment the losses etc.
Try to track possible design specs which are missing (e.g. CO2 mole flow rate in stream "CO2" is not equal to sum of losses of CO2 with streams "BLEED", "PRODCRUD" etc) or are impossible to be fulfilled (contradictions, etc)
3. Reconcile streams (see Run>>Reconcile All Streams).
Steam Methane Reforming Mass BalanceStarted by Guest_buskivi_* , 05 Jan 2025 |
![]() Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
Maximum Mass Flow In A Shell & Tube Heat ExchangerStarted by Guest_DonStalke_* , 22 Sep 2024 |
![]() Need Help To Figure Out How To Make Mass And Energy BalanceStarted by Guest_James Clerk Maxwell_* , 20 Aug 2024 |
![]() Mass And Energy Balance For Column / Confusion With UtilitiesStarted by Guest_weliketorave_* , 19 Aug 2024 |
