Fans Acfm Calculations
fan power calculation
#1 Bal
Bal
  • 89 posts
Posted 29 October 2015 - 01:40 PM
Aspen Hysys provides (Fan actual volume flow) under properties tab. How accurate it is? Can I rely on it in stead of calculating the ACFM  using the GPSA procedure?
Thanks!
#2 Bobby Strain
Posted 29 October 2015 - 08:16 PM   Best Answer
Surely you can do the math to check whether it is accurate.
#3 breizh
  • 6,939 posts
Posted 29 October 2015 - 08:43 PM
hi ,
Bobby's comment is right .
This resource may help you : http://checalc.com/solved/volconv.html
#4 Bal
Bal
  • 89 posts
Posted 30 October 2015 - 03:28 AM
Thanks a lot.
Breizh, I couldn't open the link that you've recommended. Could you check that out?
#5 breizh
  • 6,939 posts
Posted 30 October 2015 - 03:33 AM
It's fine on my computer !
#6 Bal
Bal
  • 89 posts
Posted 30 October 2015 - 03:46 AM
Thank alot :)
#7 Bobby Strain
Posted 30 October 2015 - 09:12 AM
Of course, you still need to confirm that this calculation is correct. If you search here, you will find a fan calculator that I recently posted. But, like all such software, you should check it to assure the results are correct.
Edited by Bobby Strain, 30 October 2015 - 11:24 AM.
