Hello everyone, I'm trying to design a de-ethanizer to separate methane,ethane from C3+. I have already build the tower using VMGsim. Now I'm trying validate the values I got from this software through hand calculation. Im planned to do this using macabre-thiele method by creating a pseudo-binary system of ethane vs propane. The problem is that I can't seem to find the VLE data for this system. Usually, I could use the raoults law, antoine equation and daltons law to generate a set of VLE data but I can't since dalton's law only applies for low-med pressure system. Whereas the de-ethanizer column I'm designing is at 2600 kPa operating pressure. Is there another way that I can generate VLE data for ethane vs propaneat high pressure?
Thank you
