Dear All;
Please, In the vacuum distillation unit, I've a doubt to calculate the pressure drop through control valves located on Light vacuum gas oil / Heavy vacuum gas oil / vacuum residue and inlet feed to the unit.
Example:
The pump hydraulic for vacuum residue pump "see attachment", showing the pressure drop through control valve = 0.7 bar (minimum requirement)
But the client highlighted that the pressure drop through the control valve shall have at least 4 bar @ rated capacity.
Also, the existing vacuum unit, the existing control valve data sheet showing pressure drop 4 bar @ rated capacity.
I don't know why ????
I want to know if there is any other process requirement that shall be considered in pressure drop calculation for control valves in above mentioned services or not????
Generally I calculate the pressure drop through control valve as 0.1 X circuit pressure drop "without the valve" or 0.7 bar, whichever is greater (If upstream and downstream pressure are interdependent).
Or 0.05 X pressure discharge vessel or 0.7 bar whichever is greater (in other cases)
I can understand that the inlet feed control valve shall have higher pressure drop than above mentioned criteria to keep the pressure upstream the control valve > vapor pressure.
In other cases if the stream is heated in heat exchanger train as crud oil, it's better to keep higher pressure drop in the control valve to avoid vapor lock in heat exchanger train.
