Volume Of Partially Filled Spherical Tank
spherical tank sphere partially filled partial volume volume
8 replies to this topic
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 11 December 2015 - 03:57 PM
I am doing some calculations regarding the release rate of liquids from a leak (small hole) in a spherical tank. I am trying to compute an equation for the partial volume (i.e. when the tank is partially filled with liquid).
Help is appreciated
Sherif
#2 Lucian Gomoescu
Lucian Gomoescu
  • 44 posts
Posted 11 December 2015 - 04:59 PM
Hello Sherif,
Attached you find all you need to relate liquid level with volume in case of a spherical tank.
I presented the equations for finding volume V when level L is known. For vice versa problem, you can use an Excel goal seek (adjust level until volume is equal to known V).
Enjoy,
Lucian
#3 Bobby Strain
Posted 11 December 2015 - 07:57 PM
One formula should do it, with level from the bottom to full. Two are unnecessary. Try it.
#4 breizh
  • 6,833 posts
Posted 11 December 2015 - 09:44 PM
Hi Sherif ,
Bobby is right , consider the link attached to support your work .
http://www.1728.org/diamform.htm
#5 samayaraj
samayaraj
  • 239 posts
Posted 11 December 2015 - 10:54 PM
Partial volume of sphere = pi()*h^2*(1.5d-h)/3
Where as h is height of liq from bottom of tank, d is the inner dia of tank...
#6 Bobby Strain
Posted 12 December 2015 - 07:14 PM
Would one of you scholars care to lead us through the derivation of this formula? I have gone through the formula for a cylinder partial volume, which is quite easy and straightforward. I guess if I take the time I may be able to do the same for a sphere. But I am much slower now, so I rely on code.
Just a note; if you find you want to know various geometry of a cylinder you can find same at my website. And, for a sphere, you can choose spherical heads with a 0 length cylinder. The various dimensions are calculated through a library, easy to access, and cannot be easily tampered with. You can do the same and still use your favorite spreadsheet tools. Don't stop learning when you master spreadsheet formulas. They are nasty to deal with, impossible to validate, and unrecoganizable after 2 months.
Edited by Bobby Strain, 12 December 2015 - 10:31 PM.
#7 samayaraj
samayaraj
  • 239 posts
Posted 13 December 2015 - 12:42 PM
Find attached the excel sheet to calc partial vol of spherical tank. You can also check the result from Vessel Volume calculator in the below link by selecting horizontal tank with T/T distance as Zero and head as hemispherical head. The result will be partial vol of spherical tank.
http://www.cheresour...al-volume-tool/
Edited by samayaraj, 13 December 2015 - 12:42 PM.
#8 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 14 December 2015 - 06:27 AM
Hi Bobby,
You may refer below link.
https://www.physicsf...-sphere.211433/
Regards.
Ajay
#9 Lucian Gomoescu
Lucian Gomoescu
  • 44 posts
Posted 14 December 2015 - 07:21 AM
Hello Bobby,
Attached you can find the derivation of partially filled sphere. I made it short and without much words because of the figure, which is enough to understand the notations.
You and the others were right that one formula is enough for entire range of level. In the first post i split the domain in two because i found nowhere a simple mention that the formula applies for 0 <= H <= 2R. :)
Best regards,
Lucian
