Verifying Hysys And Literature Psv Line Sizing Constraints
psv;hysys;line sizing
#1 Steve90
Steve90
  • 71 posts
Posted 30 December 2015 - 10:39 AM
Hi guys ;
I determined the discharge orifice area with hysys v8.8 ( the calculated area is equal to the result in API 520 example).
Trying to use pressure relief utility in Hysys v8.8 to Line size the inlet and the outlet tail pipes, i found that hysys uses these constraints :
Inlet pressure drop <3% Set pressure
outlet pipe avg velocity < 50 % of sonic velocity
outlet pipe exit < 90% of sonic velocity
Since i'm new, i want to know if this is correct , because i read on this forum and internet that generally we use these constraints :
pressure drop < 10 % of set pressure (if conventional)
pressure drop < 50 % of set pressure (if balanced)
pressure drop < 100 % of set pressure (if pilot)
Mach number < 0.5 for gas
which one is correct ?
Thx
#2 Bobby Strain
Posted 30 December 2015 - 11:30 AM
Looks like you are doing lots of relief valve work. What you should do is search for good material on relief valves. We don't want to continue to do your work for you.
#3 breizh
  • 6,939 posts
Posted 30 December 2015 - 09:01 PM
Steve90,
You may find some interest reading the documents attached .
Hope this helps
Edited by breizh, 30 December 2015 - 09:27 PM.
#4 Steve90
Steve90
  • 71 posts
Posted 31 December 2015 - 04:13 AM
Thank you very much Mr breizh for your valuable posts !! By the way happy new year ! wish u all the best !! :)
