Pipe spec where we need to specify... I have attached file, there are three cases which one is correct to show pipe spec.
Basically it is Fuel gas connection to flare header.
Posted 30 December 2015 - 10:36 PM
Posted 31 December 2015 - 02:51 AM
For me, as long as it is understandable where the needed spec break location it should be ok regardless of how it represent in the P&ID. It just a cosmetic issue. The main thing is make sure it is at correct location i.e. if the spec break is downstream of the valve, don’t put it at the upstream of the valve.
Kindly refer hand sketch for my previous practice.
Posted 31 December 2015 - 03:54 AM
what it means I couldn't understand farid.k ""if the spec break is downstream of the valve, don't put it at the upstream of the valve"
Posted 02 January 2016 - 07:47 PM
dear shiva,
"Spec break" happens where there is a change from one significant design condition to another.
For example, at up stream of the PSV there is a design condition with a higher pressure that requiring a higher pipe spec i.e. 300# rating pipe spec. Down stream of the PSV there is a flare collection system (or atmosphere) with a much lower design condition which is not necessary to use 300# rating. Thus it is more reliable & economical to use 150#. Therefore there would be a "spec break" at the downstream side of the PSV.
hope this help
![]() Restriction Orifice And Correct Location Of Class BreakStarted by Guest_F.Sh_* , 06 Aug 2025 |
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
Off Spec Condensate Storage TankStarted by Guest_shekhar dhuri_* , 05 Sep 2013 |
