Psv Application For Interconnected Pressure Vessel
8 replies to this topic
#1 Blesson
Blesson
  • 12 posts
Posted 04 January 2016 - 12:16 AM
Hi all,
Please share your ideas about how to introduce Relief devices for interconnected vessel.Is it required to install separate PSV for each vessel? Any supporting standards(code) for this case?
Please refer the process given below
Service-Natural gas,4-6 barg, 15-55 deg C
Vessel package description-Filter coalescer Separator ( contain two separate vessels, one is filter and other is drain collector)
Vessel size- Filter- 2X6 m, drain- 0.5X6 m
Interconnecting line size - 2" pipe, 0.5m long (3 no.s)
Vessel orientation- Horizontal(both,filter on top)
#2 Bobby Strain
Posted 04 January 2016 - 10:33 AM
What you describe is a single piece of equipment.
#3 fallah
  • 5,019 posts
Posted 04 January 2016 - 07:11 PM
Blesson,
Please upload a sketch of the system...
#4 Blesson
Blesson
  • 12 posts
Posted 05 January 2016 - 04:04 AM
Thanks Mr.Bobby and Mr.Fallah for your response
Attached system sketch
Attached File  FILTER.jpg   33.78KB   6 downloads
Edited by Blesson, 05 January 2016 - 04:05 AM.
#5 Zubair Exclaim
Zubair Exclaim
  • 123 posts
Posted 05 January 2016 - 07:15 AM
your question and sketch are not very clear.
However if there is no positive isolation between your two interconnecting vessels ESD valve etc, then you can have one PSV for both.
#6 fallah
  • 5,019 posts
Posted 05 January 2016 - 03:08 PM
Blesson,
If there is no isolation valve between two equipment or if the isolation valve(s) is LO/CSO, considering design pressures of each equipment and hydraulic characteristics of the whole system in relieving conditions, you can use a set of PSV's for protection of whole system against overpressure per ASME Sec. VIII...
#7 Blesson
Blesson
  • 12 posts
Posted 06 January 2016 - 02:10 AM
Thanks Mr. Fallah and Zubair,
There is no isolation valves between vessels.Process parameters same for both.
From your reply, i understood that, separate PSVs required for each vessel. Can you provide the supporting code/clause?
#8 fallah
  • 5,019 posts
Posted 06 January 2016 - 03:34 PM
Blesson,
If you read my post I mentioned your system can be protected by one set of PSV's and supporting code is ASME Sec. VIII...
#9 Blesson
Blesson
  • 12 posts
Posted 06 January 2016 - 11:52 PM
Thanks Mr.Fallah
