Hi all,
I have designed a HP air system. System is designed at 250 bar air pressure. Air used in the system is not completely dry. I want to reduce 250 bar pressure to 50 bar and i am reducing this in a single step (using one pressure regulator). I am using TESCOM Pressure Regulator. Pressure reduction in a single causes "Freezing" in Pressure regulator. Can i avoid this Freezing? or i should use numbers of Pressure Regulators to reduce pressure from 250 to 50 bar. If pressure reduction is done in multiple stages, then how many pressure regulators i should use and whats the distance between each regulator?
