Heat Conduction In A Pipe-
heat conduction in a pipe
#1 rrozz
rrozz
  • 6 posts
Posted 03 February 2016 - 02:03 AM
I was about to build an algorithm for heat exchanger design while there's condensation inside the tubes (not outside).
The most sophisticated corr for Nu number is by Dobson and Chato (1998), but it requires to know vapour fraction in whole multiphase.
Has anyone used correlation (eq. 10) in here?
https://www.thermalf...ve_condensation
The Martinelli parameter depends on vapour mass fraction. How to get it as it needs vapour and liquid mass fluxes to get.
I thought preparing heat and mass balance over the exchanger, but for that I need the Nusselt indeed and in general it be differential.
Has anyone used that before?
Cheers,
  • 6,800 posts
Posted 03 February 2016 - 02:34 AM
http://www.wlv.com/w...ata/db3ch13.pdf
Consider the link above for 2 phases .
