Heat Loss From Pipe With Insulation
internal flow insulation
#1 siryotis
siryotis
Posted 16 February 2016 - 04:28 AM
I'm dealing with a problem and I wish to get help.
I have a 20 m long stainless steel, 316 pipe, 1'' nominal diameter and the thickness is 1.6 mm.
Inside the pipe there is a fluid compound from mud (30 percent), diesel and oil,  and it flows at 120 oC.  The pipe should be insulated with pyrotex HLC (I asked for the thermal properties of it.)
I want that the outer surface of the insulator to be 40 oC and I want to know what will be the energy loss from the pipe with and without the insulation.
I'm struggling with this, and if someone can guide me how to solve it I will appreciate it.
Thanks!
Elad Seryoti
Edited by Art Montemayor, 16 February 2016 - 01:00 PM.
Spelling, grammar, typing, composition
#2 samayaraj
samayaraj
  • 239 posts
Posted 16 February 2016 - 04:40 AM
Hi Elad Seryoti,
Do search in this forum. There are lots of discussions made in this topic. To help you bit, check out the below links.
#3 breizh
  • 6,786 posts
Posted 16 February 2016 - 08:18 AM
Hi Elad ,
To answer your question I can share with you an excel sheet  . You will see that you need to fill in the properties of the fluid inside and outside the pipe , the data about the pipe and the insulation material , the velocity of the wind , of course the flow rate of the fluid inside the pipe...
It's an iterative calculation .
Edited by breizh, 16 February 2016 - 08:19 AM.
