Im having trouble in selection of a suitable fluid package. My components are benzene, maleic anhydride, carbon dioxide, nitrogen, oxygen and water. When I followed Seader's recommendation, it advised using PSRK, however it turned out that HYSYS does not recommended using it due to the present of Maleic Anhydride. When I followed Carlson's recommendation, I was advised using extended NRTL. Using NRTL seems to be fine at first, however I found out that my first Distillation Column (as a absorber which absorb Anhydride Maleic by a Dibutyl Phthalate solvent) is not fonction. Not only can't absorb Anhydride Maleic, but also the Dibutyl Phthalate solvent vaporize into overhead stream.
So now I am really confused and dont know what fluid package to be implemented. My problem is a wrong fluid package or other mistakes? I would very much appreciate if any of you could give me some advice about this.
I'm using HYSYS v7.2
Thanks you so much.
