please, can someone help me with my final year project which is dynamic simulation of wasterwater treatment plant....thanks for your contribution in advance
Dynamic Simulation Of A Wastewater Treatment
Posted 17 March 2016 - 06:10 PM
Posted 22 March 2016 - 03:42 AM
please i need your help
Posted 03 April 2016 - 08:12 PM
Hi Sunlias
Can you please explain more what kind of result do you want from the dynamic simulation?
Posted 04 April 2016 - 08:46 PM
thank you AlertO....i really appreciate your concern....actually i am using wastewater from a petrochemical industry as a case study....and the wastewater contains majorly phenols, BOD,COD, mineral oils chromium.....please can you recommend a software for me between chemcad and aspenplus and also help me with what you know i might need.....thanks very much
Posted 06 April 2016 - 08:34 PM
Hi Sunlias
I have less experience about simulation on wastewater treatment so i can't help you much in details. However, i try to emmphasize in some key points you have to know as follows:
1. Wastewater treatment strongly depends on the technology you use. So please ensure that you have look through many types of water treatment process and come up with the selected one which should be suitable for your waste water.
2. Many of process technologies including waste treatment are in-house knowledge and you can't use the typical simulation software to model it unless you have the experimental data which you have to create an user model and insert it into the program.
3. You mentioned aboutt the dynamic simulation, but i'm not sure what do you mean? The dynamic simulation will be done when you what to see the change of process parameter with time which is different from stead-state process simulation. Do you exactly require it?
Hope this may help you.
Posted 18 April 2016 - 05:30 PM
thanks alot alerto....information will go a long way to help me.......thanks i appreciate.......i am doing both the steady and dynamic state
![]() ![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
