I am wondering how people connect two equipment to one stream as shown in the figure attached.
Thank you.
Leo
Posted 30 March 2016 - 01:52 PM
Thank you.
Leo
Posted 30 March 2016 - 05:16 PM
Did you try just doing it?
Posted 31 March 2016 - 02:19 AM
It will be defined like this when stream 1 is going to either VLV-100 or VLV-101 which means that the flow/conditions inlet to both VLV-100 & VLV-101 is same as stream 1.
Open VLV-100 & VLV-101 and define inlet stream as 1 in both of them. You will get like this.
Posted 31 March 2016 - 10:34 AM
Bobby,
I think it is good if I know how to do this. Sometimes, I have to use "VS" function if I want another stream with same properties.
Leo
Posted 31 March 2016 - 10:37 AM
Hello Karthikram,
Have you successful attached second stream through the way you described? I tried the method before I posted the topic. It didn't work.
Leo
Posted 02 April 2016 - 05:10 AM Best Answer
hi, yes in hysys ( 8.0 and upper) it's possible, first go to file, then options, in simulation box : check allow multiple stream connections.
Edited by titim, 02 April 2016 - 05:12 AM.
Posted 04 April 2016 - 09:04 AM
Titim,
Great! It worked in Unisim 430.
Thank you for the tip.
Leo
Unisim SoftwareStarted by Guest_TunTun_* , 15 Oct 2025 |
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Top Foam Pourer Line- Reducer ConnectionsStarted by Guest_RAFAELDAVE_0752_* , 03 Sep 2025 |
